Vintage skin www
Re: Vintage skin www
Postby rika on Tue Jul 03, 2007 7:05 am
Not at the moment. Right now I hold these files exlusive for Steven and xlobby. Maby later...
Rika
rika
Postby Froggy on Wed Jun 24, 2009 5:54 pm
Rika, I love your Vintage skin!
Is there a way I can use the xLiveShout plugin with that skin?
Turns out that the Radio section is what I use the most on xLobby. Thx!
Froggy
Postby rika on Mon Jun 29, 2009 4:07 pm
I´m on vacation, sorry for a late answer.
Nothing fansy but HERE you are.
Rika
rika
Re: Vintage skin.
Postby Froggy on Fri Sep 04, 2009 8:25 pm
Thank you! No problem with the late answer. Mine is quite late also.
Well, what do you think of this case? Wouldn't it be the perfect match for the Vintage skin?
http://www.nmediapc.com/htpc8000.htm
Froggy
Postby Marbles_00 on Fri Sep 04, 2009 8:46 pm
People over at AVS discussed this case: http://www.avsforum.com/avs-vb/showthre ... =htpc+8000
Mixed views on it.
A guy on the second page of that thread put a system in a 1930's radio case...really neat looking, he did a good job.
I personally like what this guy has done with his cases:
http://www.slipperyskip.com/index.html
Previous
