very simple : launch MPC
View / Options / Player / Keys
The name of the command is in the first column and the code is in the ID column !
You can look at the skin XMedia2 by Sagitaz
http://www.xlobby.com/forum/viewtopic.php?t=2988 Sagitaz use MPC in his skin
