Guys, I am in a confused state and in a bit of a quandary in relation to my use of xlobby and I need your advice please !!!
Before I go on, I wish to preface this post by saying that I think this front-end is fantastic and that Steve is doing such a great job developing it. Of course, you guys providing assistance in the way you do is great too, skin development, plugin support, forum contribution etc etc. Its all good as far as I am concerned. Please don't take this email as being critical.
Here is my situation:
Zone 1 - Living/Lounge Room : HTPC feeds projector (AE500 native 1280x720), audio REVO via S/PDIF to Meridian processor, to Monoblocks and power amps, to speakers (I will probably ditch the Meridian and use the HTPC for direct analog out to the amps with REVO or improved sound card (experimenting)
Zone 2 - Main Bedroom : PC - Basic 2.4Ghz Celeron etc (for zone audio only), Yamaha receiver available, Bose cube speakers
Zone 3 - Bedroom 1 : PC - Basic 2.4Ghz Celeron etc (for zone audio only), Pioneer receiver available, Bose cube speakers
Zone 4 - Office/Bedroom 2 : PC - P4 2.8Ghz (for zone audio only), Kenwood receiver available, Bose cube speakers
TabletPC - 10" native 1024x768
PDA #1 - WiFi 802.11b
PDA #2 - WiFi 802.11g
The 4 zone PC's are connected to a Gigabit network, and I have a 4 port wireless router connected to that to account for the 3 wireless devices. I also have a seperate PC dedicated as an Internet server with a firewall etc. Oh, and I have a separate 2TB Raid 5 Media Server (and a host of other drives in various of the other PC's).
The acquisition of the tabletPC was done fairly recently, with the view that it would be the control piece of xlobby for the living room (ie for movies and HDTV mainly). I was previously trying to use one of the PDA's for everything, which is now/or will be relegated to music control around the house. The other PDA is used for work but is always home with me - when I am home.
The 2 problems I have with xlobby are:
1. Using the tabletPC to control xlobby on the HTPC, is that it has a different native resolution to my HTPC. Thus when I use either the thin client or the web server client on the tablet, the resolution is screwed. This is a major issue.
2. Using the thin client or the web server client on the tablet (or any PC for that matter) does not give you the full features of the skin (ie: highlighting/selecting of buttons, pop-up graphics etc).
What/how can this be sorted ? Am I overlooking something obvious ? What would you do if you were in my shoes ?
I was trying to think latterally, that perhaps I could use the tabletPC as the xlobby server. The tablet would then tell the HTPC to play music using winamp on the HTPC and to play movies using Zoom Player on the HTPC. It seems (again I might be wrong) that Xlobby does not permit the server to send commands for Winamp and Zoom Player on another PC (operating system). Hence it might only work by using say Girder at both ends Xlobby tells girder on the tablet to send Internet Event eventstrings to Girder on the HTPC, which in turn send the relevant commands to Zoom and Winamp. I suspect in Girder you could use the Internet Event Client/Server plugin. I dont know how hard this would be to do, to make xlobby talk to girder on the tablet. This would be the hard bit. Sending the IEvents from Girder to Girder should be okay ??
Is anybody else doing this, tried this or has thought about doing this ? I have thought about a Netremote solution, but the GUI sucks and I really like Xlobby and want to be a long time user and to see it developed into the ultimate front-end (if its not that already).
I'm also confused about how to proceed with the mutlizone audio and how to acheive stable synch in the zones, but I will try and cover this in a different post.
Sorry for the length of the post.
