Would it be possible to add a field to the movie database to designate what format the movie is in Blu-Ray, HDDVD and DVD? This could help me launch the appropriate software for the movie to play.
Wes I think you can take this one off the list. After searching through the support thread I found some posts on Meta Masks that showed how to dynamically create a field in the database. After some playing around and deleting all of the item.xml files I was able to successfully create a format field and have is populated with DVD, HDDVD, and BluRay.
