I have been using xlobby for about 2 years for music and movies. Recently after an upgrade Winamp closes when the pc goes to sleep. This was not the case before the upgrade, so I assume there was some change in Winamp. I am using ver. 5.22 I believe the prior version was really old, 5.0x
I connect to this htpc which really is the server using a pocket pc to play music on outside speakers. The pocket pc screen displays xlobby and navigates as it should. When I try to plat a cd nothing happens, I then go to the basement and look at the monitor for the server and xlobby is running but Winamp is not.
running most recent xlobby as of 2 weeks ago. xp pro sp2 for OS
Any help is appreciated Thanks
