So here are my two questions.
I have xlobby on a laptop that will be in my truck. I use my cell phone to dial up my laptop. How can I make it so when xlobby starts it doesn't try to dial up? (ie, brings up the windows dialup config, not catastrophic, but an inconvenience to have to close)
Also, that laptop is going to be used as a wireless AP (using a RAlink card) and I'd like to be able for xlobby to make the laptop dialup when I do connect my phone (easy to do using execute os app command) but I want to be able to disconnect it just as easily (with xlobby). Is there a way to do that correctly?
most of you probably know that I don't write scripts and all that crap, but I can modify some stuff to fit it for my applications if need be.
any help would be cool
ben
