If you need a good client screen
for my thin clients, i used a TFT LCD touch screen ($242) cheap, and works GREAT
10.4" display, then i use vga extender over cat5 by KVM, simple wall plate, plug in and go.
OK here comes my $.2 from the peanut gallery,
now when you guys talk about zoning.
are you referring to each fat client being it's own zone?
the way i'm currently setup, i have the server with all the music.
2 fat clients that connect thru xnet to a central server.
when i play music on one fatclient, i use the audio out from the fat client pc to speakers in that room.
is that considered a zone?
or
should there be one server, and all the music goes from the server to all the speakers in the house directly.
does anyone happen to have a schematic on how they have their layout. showing routers, amps, speakers, etc.
pictures are worth a thousand words
