I am currently working on the support documentation and making things more generic. I will test things using clean XP builds later to ensure I do not leave any machine specific hard coding in any of my scripts.
Here is a v0.1 screenshots, scroll down for the download.
DOWNLOAD VERSION 0.1 HERE
http://www.xlobby.com/files/XiVo/Xivo.zip
The first release is a widescreen 16:9 1280p format in just the one colour - purple. It is designed to be driven from an IR remote using Girder with the supplied GML file located in the commands DIR. It also heavily uses custom batch files and vbscripts for the TV series pages, best to wait until I have finished the docs before you play with them too much!
I use custom settings on the File Types association TAB which I will explain in my documentation, in the mean time here is a copy of my types.xml if you want to see what they are, right click the link and 'save As'
http://www.xlobby.com/files/XiVo/types.xml
why have I grabbed the first 3 replies?
So that I have room to always post the most current information at the head of the thread.
