How do I delete buttons - newbie question
Postby ellisbailey on Mon Oct 31, 2005 1:49 pm
I have elected to use Xlobby as my frontend for my htpc and am slowly learning some of the in`s and out`s of this great piece of software.
for my interface I only want three main options - movies, music and pictures
How do I go about deleting the other options such as webcam/files etc?
I am using the default skin
Thanks in advance
ellisbailey
Postby Naylia on Mon Oct 31, 2005 2:11 pm
press 'Pause/Break' key and that will bring up the skin editor, then just click the button you want to remove and press 'Delete', or you could also check the 'Hide' button in the skin editor so that it'll be there if you want it back later.
Naylia
Postby ellisbailey on Mon Oct 31, 2005 2:49 pm
Thanking you.
All sorted
ellisbailey
