....well, I have been at this damn zoomplayer issue for a couple of days, and it is really pissing me off!
Using the latest version of xl and heavy metal skin...installed xoap and winamp and .net 1.1. I have zp 4.03 PRO, and have ffdshow configured just right.
If I run zp outside of XL, it works just peachy. If I run (try) it inside of XL, I get the popup window PLAY COPY CANCEL. If I click PLAY, nothing happens. The button doesn't even turn red when you click it. The COPY button does nothing either. Did a site search, and played with a few different command-line parameters. Got pissed, and buleeted the xl folder and started over again, following the correct order as laid out in the HELP section (Jowaldo). Nothing. OK...let's change gears....tried default skin...nothing....tried Jowaldo's new skin...nothing...this sux!
Can I get ANY assistance with said problems please?
TIA
qbnkiller
..about to test the sinkrate of this damn computer!!!
