prompt to install flash
Postby Atlas on Tue Jun 06, 2006 3:54 am
I'm having some weird behavior with xlobby. I installed the latest with the new installer. I also kept my "working" xlobby directory. I was playing around with the "installed" version to get it setup. Now going back to my "working" version I get prompted to install flash 8 every time I start the "working" xlobby which never happened before. I tried removing every plugin, turning off all loading of RSS, http, etc on startup and still get the prompt on startup of xlobby.
Anybody seen this before? Have any ideas to look where it is coming from? Thanks.
Atlas
Postby Colby on Tue Jun 06, 2006 4:17 am
What skin are you using? If there is a shortcut to a webpage containing flash IE will want to install it. I know my skin has links on the browser page to flash sites. Also, is your animation enabled in the setup menu?
Postby Atlas on Tue Jun 06, 2006 5:10 am
Thanks Colby that got me going in the right direction. I was using HeavyMetalX_WS and there is a page called 'guide' in it which I don't use. However one of the buttons had the image as "http://www.titantv.com". I guess titantv added flash to that page so I just started getting the popup.
I hate it when something changes like that on the same day I do some tinkering....not good for the sanity level! :lol:
Atlas
