Command Line
Command Line
Postby theendisnye on Fri Jun 11, 2004 5:34 pm
Is there a simple way to run a program and associatted paramers (as if from the command line) by hitting a button in Xlobby? Steve
theendisnye
Postby Arthur on Fri Jun 11, 2004 7:47 pm
yes there is.
In short: create an event and link it to the button.
Step by step:
Hit F2, choose event manager tab -> choose skin -> hit "add group", call it "my commands" or something.
Hit "add event", call it "my event" or something.
In the list on the right, choose the "os" section.
Now you can chose send command, fill in the items (class name etc can be found by using girder)
Ok now you have created an event.
Now all you have to do is create a new button:
Hit "pause/break"
screen --> add button
Button --> event --> "assign", choose you new command from the list
Arthur
Arthur
