I think you and I have been pursuing a very similar path to multizone. But I think you are a couple of steps ahead. Would you be willing to walk me through a few things so I can catch up?
Here is my setup (initially only using 4 zones off the first 410:
Server 2.4 GHz P4
Sound Card 1: M-Audio 410
Sound Card 2: M-Audio 410#2
XLobby 39 or 40? (I will be going server/client with a Dell Axim as client)
Winamp 2.x or 5.x?
PPC 802.11b Axim X5
Questions:
What build of Xlobby are you using? Can you briefly walk me through the Xlobby setup? Any pitfalls you ran into or other advice is what I am looking for...
What version of Winamp are you using? Is there is some tweak needed to get 5.x to work? How did you install the Winamp, just re-run the install app and state a new directory or did you copy the directory from the first install to each new zone? Again, Any pitfalls you ran into or other advice is what I am looking for...
M-Audio setup: What drivers did you use...any special options you selected during install or did you just go with the defaults?
Are you using PPC control yet? If so, any advice on that route would also be helpful.
thanks a huge amount!
