thekochs,
Save the xCoverResize.dl_ from Sean's email to your xlobby/plugins directory (Most likely c:\program files\xlobby\plugins)
Start XLobby
press F2 for the setup screens and go to EVENTS
Under events, find your PLAY MOVIE event (most likely under MOVIES, but will vary depending on which skin you are using)
Click on the Play Movie event and at the bottom click ADD COMMAND
On the right, at the top, find the PLUGIN group
the plugin will be xCoverResize
the Command will be make bmp
the parameters will be the one in Sean's post (%music>coverart%, etc) INCLUDE THE * as this is the serarator that his plugin is looking for. Also verify the path to your theatertek program. You can use the size parameter at the end (the *200*300) if you wish. It's up to you, I don't use this.
click ADD at the bottom right and then use your mouse on the left to move the command to the top of the play movie event so it's the first command in the list. Press CTRL-S so save the changes (just in case) and exit the setup screen. Go to your movies page, choose a movie and click on play movie. Now, hopefully if I haven't missed a step, you will see the coverart come up on the monitor/TV you use to view movies and then your movie will begin playing.
Hope this helps. Please understand, I'm typing this at work from memory, but I don't think I skipped anything. Let me know if it doesn't work and I'll help you get it working.
Thanks!
