Firstly, good luck with the venture, and cheers for a great product and all the great support you have provided!
That said i have to re say this - I think you can cut the waffle on here down to one question basic question, whats it going to cost...
I think that this is not an unreasonable request, i know you cant be too specific, but like i siad a while ago i think you can break the users here down into 3 groups (almost all with modded skins) -
1) use as a media interface
2) use a a media interface + multizone
3) systems that do everything from home security to closing the curterns at night
i know you cant price 3, but i would have thought that the first two could be guessed at?
if i have an idea about that, then i can make a better guess about what i need to do, rather than wiat 4/5 months and find that it would cost me XXXX to use a legit copy of xlobby...
Do i carry on messing with my never quite finished skin?
Do i try new features as you release them? (the answer would be yes, jsut to give you some feedback, but you know what i mean)
Should try and get any plugins i have wrote, wroking for other poeple? (i know its not the same as supporting xlobby
but it still burns up a few nights trying to figure out why the hell it doesnt work for Xxy
The truth is all of these qustions boil down to the cost...
And on the plugin front, it would be nice to know if they will still be supported or will there be a full scale re-write of the interfcae on the cards?
It would be good if they carried on working...
but if the interface could be expanded to included more functionallity, it would be very nice (there are a few threads about expanding the interface).
if there was a nice interface i bet a lot of existing plugins could be easily re-writen/ported (most of mine are full of hacks to get round limitations anyway!)...
a more complete plugin interface would let people release better more functional plugins, which would have to be a great assest to a "real" product.
And of coarse you would get some free coding done as well
