General program question regarding xlobby
Postby Parout on Wed Jan 19, 2005 7:25 pm
I am very interested in trying Xlobby rather then Girder. I want something with a more polished front-end (OSD) then what I have seen from Girder. The question is, will it work with a Tira-2 IR board? I bought this from home-electro.com and they list Girder as a compatable software but I don't see Xlobby. My guess is that they aren't aware of Xlobby. Any insight you can give would be appreciated. You can see the hardware I am working with at:
http://www.home-electro.com
Parout
Parout
Postby erikt on Wed Jan 19, 2005 9:01 pm
I may not have the exact answer you're looking for, however you
don't have to replace Girder with Xlobby. They work really nicely
together. If the Tira-2 isn't supported directly using the USBUIRT
plug-in, then you can use Girder to interpret the Tira-2, and pass the
events to Xlobby.
I'm using Girder together with Xlobby to control my VFD, and plan
to use Girder to pass events to Xlobby from the VFD's keypad.
erikt
erikt
