Alright, I created 3 databases NF-Queue, NF-Rental, and NF-Recommend all based off the NetFlix feeds.
Lets go through adding a screen and the NF-Queue it.
With Xlobby open, start the skin editor, Pause/Break key. Navigate to the Screen tab and Add subtab.
Type in your new screen name like NetflixQueue then click Add. You should now have a black screen. If you want the main background image used then click the Edit sub Tab and select the background. To add the database to the screen you go back to the Screen > Add and put NF-Queue in the Category field and click add. Now you should have a box with a dashed green line and nothing in it. That is your category. Goto Item > Category > Database and find the NF-Queue Database and select it.
Once you do that you will see the List of movies in your queue. You can resize the category as you wish. You probably want to add a button from the Screen > Add Button tab and assign it a Click Event of “goto:goto main” or goto what ever screen you chose.
That should get you started, nothing like a crash course.
If you have problems let me know, I got to get some sleep for now.
