As u might have noticed in kX-DSPs epilog there is digital outputs beyond regular analog ones, for me it appears they are discreet (except one which is shared with headphones) meaning that putting out different signal to them should be just matter of kX-routing. So if these can be utilized it should raise number of zones (stereopairs) out of audigy 2 card from 5 to 7... meaning u could actually output 14! mono zones if u would choose so. For live! family corresponding numbers would be from 4 zones to 6 (allthough in case of live! the solution would be slightly more complex cause card itself lacks separate physical digital out, meaning that more expensive model with digital din output module for creative speakers, or some creative cabling would be needed)
Well output was never a problem... but how would u input 14 channels into kX-DSP?? That is where ASIO comes into play. WinMME limits inputs to kX-DSP for those familiar 5 pairs for audigy (0/1, 4/5, 6/7, 8/9, and HQ)... but with ASIO u should be able to insert atleast those 16 channels u see in FXBus and therefore make use of all analog and digital zones. Right?
I tested my idea for short while, but unfortunately i couldnt make Winamp ASIO output plugin to work for me. So i thought mayby other kX-users with more demand for extra zones would like to know about it and possibly try it out...
