by m_ski on Fri Jul 21, 2006 11:21 am
You are probably playing the DVD in video overlay mode. This is only supported on the primary monitor. You need to setup zoomplayer to use VMR7 or 9 (Video Mixing Renderer) and then I think you'll be able to play movies on both screens.
If you go into DVD settings then I think you can set it to use VMR7 or VMR9.
Try the zoomplayer forum for more advice if that does not work.
