by Marbles_00 on Sun Sep 11, 2005 5:40 pm
You might want to check out the XMedia skin by the French team. It allows the user to select different colors for that skin. Not sure how they did it, but it may be a starting place for you. Their MediaX skin, I think, does something like that as well.
Besides, both those skins are pretty cool, nicely laid out and well worth the look regardless. If you don't know French, then you will need the English translation for the XMedia skin (posted somewhere on Xlobby.com to download).
Hope this was helpful.
David
