Mimic mode... Question
Postby Aaron on Sun Dec 05, 2004 6:45 pm
Steven,
Is it possible to place the entire skin in multi-way 'Mimic' mode?
I'm using Colby's new skin and when I turn Mimic on it works fine from my Neta980 WinCE touchscreen... I change the 980, the XL server changes it's screen. But, it does not work the other way... when I change the server's screen, the Neta's screen stays the same.
BTW... the response time for the mimic commands is very fast, almost instant screen changes on the server!
The problem I found is the screen refreshes/changes are a consistant 3 second delay for the Neta. If there is any way to do an image cache on the client I think you'd have the killer wireless touchscreen controller!
thanks!
Aaron
