columns in category
Got an idea, post it here
columns in category
Postby dalanik on Tue Sep 07, 2004 8:57 am
I'm experimenting with nr. of columns in category when displayed as thumbnails...
It'd be nice if we could:
* have columns when category is displayed as TEXT
* have command to SPECIFY number of columns, instead only increase/decrease, because not all col. nr. show up OK.
* have command to TOGGLE between multiple column numbers. i.e. Toggle columns 2/4/8/12. (other nr. of columns i.e. 3/5/7... don't display well).
D.
Postby Colby on Tue Sep 07, 2004 1:24 pm
I would like to just simply specify rows and colums. 4 across 3 down. ratio=2:3 thats it.
and have this for text view also.
Postby dalanik on Tue Sep 07, 2004 1:40 pm
The reason i want TOGGLE columns is that then you can use only 1 button to toggle. This way you'd need 3 or four buttons if you want to have possibility to swith between 3 or 4 column count...
D.
Postby Colby on Tue Sep 07, 2004 2:12 pm
Yeah that would be good.. I second that
