Greetings again,
When I switched my skin and such over to a different computer, I ran into a new problem. Again I searched these forums and didn't find any discussion of it, but this one might just be my not knowing what the right terms to search for were.
When XLobby starts, the games database does not show up -- the category database browser thing is blank. Not sure if it matters, but this browser is on the startup page for the skin. Now, when I go into the skin editor and select the object and go to the category/database tabs, the database that it is supposed to be tied to isn't selected. Some more info in numbered form for easy reference:
1) - If I select a different database, say "movies", and then select "games", all of the games pop up onto the screen like they should have been.
2) - If I select the games database without selecting another one first, they don't show up.
3) - Without going into the skin editor at all, if I go into the F2 menu, select databases, select games, and hit the refresh button, the games database browser is populated and works.
4) - triggering a games category refresh via event does NOT work, despite #3
5) - If I do #1 or #3 and then quit out and restart, it's back to not being tied to the database again upon reloading.
6) - This problem is all on one of two computers. The other computer works fine across the board.
7) - I've tried moving all kinds of things from the first computer to the second, up to and including the ENTIRE Xlobby folder.
I feel like I must've done something wrong... because I can't think of what would be different causing one to work and the other to not work. Has anyone seen this type of behavior before or know what I might have screwed up?
-VRS
