Ok, this may seem to be a wierd question, but I'm asking it anyway
One screen I have is for home automation using Manny's ideas to send information back and forth to PowerHome which actually controls the lights. If I have the thick client on 1 machine and Xlobby with XNet server running on another, using xnet to connect the 2, I can control the lights from the thick client because they are sending information, but the buttons don't currently get updated from powerhome if a switch is manually changed, etc because IT'S updating just the server. Is there a way to keep just this 1 screen in sync between the 2 (or more in the future) without having to make PH send the updates to 2 units? I know my other choice is to go the thin client route, but would like the flexibility and speed of the thick client if this is possible.
Thanks!
