stevenhanna6 wrote:I think the general point was that there was no spider system that could do the whole db unattented. Well now there is so no more complaining! just kidding, its something that we needed and it wasn't that hard to add. I can understand the frustration in getting so many covers.
You will need the new exe
and you will also need to update your spiders
http://www.xlobby.com/spiders.zip
Just go to the advanced spider section when editing a db, and click a spider...( I suggest amazon-dvd, since I just fixed that one up) and uncheck the check box if you want to redo all the covers.
Good night, before I can type a response you've coded a solution!
OK, so now I've offered some beta testing, here goes...
BTW, is there some way I can backup the work I've done so far before moving ahead with this?
