photo slideshows in V3?
Postby S Pittaway on Fri Dec 21, 2007 9:10 am
Just a quick question regarding photo slideshow support in the next version...
Will it work as it does now (ie its a bit naff) or will it support things like the kens burns effect/panning-scanning etc?
Also will it allow you to view the photos on a differant monitor to the one xlobby runs on?
Before the Calrad takeover I was working on a plugin to do this, i just wondered if i needed to finish it off?
If you have moved over to .net 3/WPF it is actually very easy to produce a nice looking "animated" slideshows using only a few lines of code (i was very impressed compared to how much C++ code there would have been...)
To be honest, decent picture support should be built in mce/media-portal (2 & 3) all have "nice" looking picture screens.
Re: photo slideshows in V3?
Postby lar282 on Fri Dec 21, 2007 12:00 pm
I agree.
We need atleast rotate function
Postby capecodscot on Fri Dec 21, 2007 3:37 pm
+1
capecodscot
Postby S Pittaway on Fri Dec 21, 2007 5:18 pm
yep, the rotation is very important, in my plugin i did it the way Steven sugested, it simply sets a "rotate" flag in the database, and then uses this when displaying images...
I know the save jpg code is a bit rubish.. so it doesnt downgrade the original image.
Postby wesblack on Fri Dec 21, 2007 7:17 pm
Sean,
Yes we plan to add all these effects and more, camera click sound effect options, etc.
Postby S Pittaway on Sun Dec 23, 2007 11:06 am
they are so esy to do i assumed they would have/will be added.
i will write the old plugin off a wpf expirement and find something else to "break" over christmas :)
