Add playlist name variable to "Save Playlist" even
Got an idea, post it here
Postby joeb on Sat Aug 20, 2005 11:59 pm
When saving a playlist, I'd like to popup the keyboard, so I can type in a name for the playlist. I'd save the typed name into a variable, and then call the "save playlist" event with the variable.
Is there any other way to change the name of a playlist without going to the db editor?
joeb
Postby Colby on Sun Aug 21, 2005 2:59 pm
Supposedly there should be a way to rename things from within XL. I never got it to work. It involves button input and variable set. I guess I can try some more, and post my solution (if Ifind one).
Here is the other topic http://www.xlobby.com/forum/viewtopic.php?p=21575#21575
Postby lar282 on Sun Aug 21, 2005 6:59 pm
I think u can do it with the default skin.download and try. I am almost sure u can.Cant try right now, wrong computer.
