Helle,
here is a new plugin allowing to show runtime information (title, time, progress bar) for those using Media Player Classic (MPC)
http://users.skynet.be/badubo/test/XMpc.zip
Copy the content in "plugins"
You can access several information from the running MPC instance like :
plugin>XMpc>Title
plugin>XMpc>File
plugin>XMpc>Pos
plugin>XMpc>Remain
plugin>XMpc>Total
plugin>XMpc>Full
and a progress bar :
plugin>XMpc>Progress
If you want to change the look of the progress bar, simply change the 2 .png in the directory
