by lynbark on Tue May 03, 2005 5:22 pm
Love the idea as our touchscreen with Xlobby is a few steps away from the kitchen. I have a few problems adding this to baddabing's skin I am using (and love!)
I downloaded the recipe files and placed them the BONG skin folder, and the eventgroup folder.
I ran the file to convert the text files into the MealMaster xml file.
I ran skin editor and added a button to goto recipies (as it is spelled) and it will take me to a new screen with a few buttons missing (i guess these are not in the BONG skin).
My problem is, when I place the MealMaster xml into the BONG skin folder, xlobby stops loading at SCREENS.
If i put the mealmaster xml into teh eventgroups folder, i don't see any recipes at all.
So I can navigate to the new recipes screen, but nothing appears.
Can you tell me exactly what I have to do as far as assigning events, possibly copying buttons from 1 skin to the skin I use, where the MealMaster xml belongs?
Thanks!!!!
