This is a 6.5" NEC model number NL10276BC12-02, XGA (1024 x 768) industrial touchscreen with 3M Microtouch *serial* controller. I have the drivers to email and will include the short VGA cable and power adapter that came with it.
Screen is bright and crisp (much better than I have photographed) and touchscreen is very responsive. These things are built well, but they are used. One thing to note is that it has no power switch, per se. When plugged in and not fed a signal, it will blink a "no signal" message. So you will either need to make a power switch, or do what I have done, which is to power these with the PSU from whatever computer they are used with.
I'm looking to get $120 shipped.
If interested, write me at mgbaughan AT verizon DOT net.
Thanks.
