Can xlobby send command line switches to an external program
Postby dwl on Thu Jul 28, 2005 11:25 pm
Hi all, The subject says it all! Ive got the command line switches for dvddecrypted, eg
/DEST "" |
Used to select the destination folder, filename or drive.
Folder applies to IFO and File modes.
File Name applies to ISOREAD mode.
Drive Letter or SCSI Address applies to ISOWRITE mode.
Examples: /DEST "C:\DVD 1\VIDEO_TS\"
/DEST "C:\DVDIMAGE.ISO"
/DEST J:
/DEST 1:0:0
Can they be used in xlobby?
Cheers
dwl
Postby rubbah on Fri Jul 29, 2005 7:03 am
think there is a plugin for dvddecryptor, but yea they can be used
hit F2 select events>commands>os> there you got execute file.
enter you're commend line switches under arguments
rubbah
