Xtuned Volume 1
Postby cavitycr33p on Fri May 21, 2004 6:34 pm
Works great Air! Everything looks and navigates just right with the new res.
My wife gives thanx also.
If we could just figure out the going back to home bug....and the metamasks so i can display my organized music and movies.
cavitycr33p
Postby C-moi on Fri May 21, 2004 10:05 pm
Airpost
i found the solution
open the weather.xml file (in eventgroups folder)
search string
<parameter>weatherinteractive</parameter>
change with
<parameter>overlayweatherinteractive</parameter>
enjoy !
C-moi
Very nice...
Postby panos_k75 on Sat May 22, 2004 12:13 am
Very beatiful skin. However I was playing around with the search functionality in the Music section and it only seems to work if you use the mouse. When I navigate around the letters using the arrows only, then the results disappear for some reason.
There's a few other little things as well, especially when browsing around with the arrows/remote (Sometimes xlobby crashes when i use keys to browse around but not sure if that is a skin problem or not).
Apart from those little issues excellent skin, pleasure to watch.
Keep the good work up.
Panos
panos_k75
Postby cavitycr33p on Sat May 22, 2004 12:21 am
1 question
1. Have you thought about adding a games section, or are you not using it with that purpose in mind?
cavitycr33p
Postby AirPost on Sat May 22, 2004 1:08 am
Panos, I don't have this keyboard/remote problem on my system. I tested it out and the music search works just fine using keys or remote. What pre version are you using? Also what remote/software combination are you using?
Cav, I'm not doing games on my htpc but I will include it on the next release.
AirPost
Postby cavitycr33p on Sat May 22, 2004 1:43 am
Awesome, if it could be setup like the movie or music database, but with roms...man...this skin is the shiznit
cavitycr33p
Postby Twit on Sat May 22, 2004 3:44 am
Airpost - friggin awsome.
Panos - This was a problem in 14 (i think) make sure you use 17. I posted this bug in the announcement section of 14 and steven fixed it.
Twit
Postby panos_k75 on Sat May 22, 2004 9:07 am
Thanks for your help guys,
I installed pre.17 and now everything is smooth.
Excellent stuff.
Panos
panos_k75
Postby mkaylor on Sat May 22, 2004 12:32 pm
The favorites pops up under the browser window instead of on top. This locks up the system. Anyone else having this problem?
Mike
mkaylor
Postby mkaylor on Sat May 22, 2004 12:45 pm
Forgot, I have a second problem in that my movies and albums artwork doesn't show up. It just places a white box with the name across the top. It works with the default skin. Any ideas?
Mike
mkaylor
Postby cavitycr33p on Sat May 22, 2004 2:01 pm
No idea, not having those problems here, anybody else?
cavitycr33p
Postby rungabic on Sat May 22, 2004 3:08 pm
AirPost,
Your skin looks fantastic, but any chance of a lowly 800x600 version for those of us with smaller standard aspect ratio touchscreens? (1024x768 would also be a great res for the future, but unfortunately my 12" touchscreen is only 800x600...)
Brent
rungabic
Postby AirPost on Sun May 23, 2004 3:52 am
Mike, per the guide, the internet favorites overlay doesn't seem to go in front of the webbrowser so I might need to redesign the screen and just put the links on the left hand side next to the browser like the default skin.
As for the movie covers, can you check the category by loading up the movie screen, going into the skin editor (Pause/Break), clicking on the movie category (where the movie covers are), then go into Edit Category and see what is shown and if matches this (on the 856x480 res.) -
Info Screen: movies
Display: %display%
Thumbnail Layout: Enabled and default
Columns: 6
Ratio 2:3
Also, what version are you using?
Rungabic, will do an 800x600 but will just take awhile. Will let you know when it's available.
AirPost
Postby mkaylor on Sun May 23, 2004 2:12 pm
I'm using the 640x480 skin. When I did like you ask, it says No category has been selected. Also noticed when I select a movie, then go back to the previous screen, it will only show 1 or 2 movies. Not all of them.
Mike
mkaylor
Postby pateruck on Sun May 23, 2004 6:34 pm
Excellent skin!!! It convinced me to upgrade xlobby from the old version I was using. I have not found any real problems yet. I did edit the Burn DVD to Play DVD so I could play rentals. Not putting the text into the button image was a very good move. I am using girder for remote control and it is working fine, but I don't know how to setup xlobby to use remote without girder. My PJ is 960x540 but the 858x480 looks awesome. Hopefully you will release a 960x540 version so it will look even better. I second the vote for a games section. And, maybe I'm missing something, but is there a stop button anywhere for the music section? And the visualize options is a great idea. How can I make the visualization display full screen when I click the button? Keep up the good work. This is the best skin I've seen.
pateruck
