In an effort to control all my devices with just one remote, I am trying to get a Logitech Harmony 659 to work in Xlobby.
I am using the IR receiver that came with a Microsoft MCE remote to capture the signals from the Logitech 659. The Microsoft remote works well within Xlobby, so I figured if I taught its navigational commands to the Logitech 659, it too would work. It kind of works, but inconsistently, and is not going to be useable as it is working now.
Is there a plug-in I should be using? Or should I use Girder? Or should I be using something else? What do I need to make this work propery?
Thanks for any help.
