Is there a way to cut and paste a button in the edit skin menu ?
I wan't to add a couple of power buttoms to my music and radio page.
Colby wrote:Yeppers, but not in the menu.
Cntrl+X to cut
Cntrl+C to copy
Cntrl+Z to paste
Same as any program
Hold shift and drag from the upper left to multiselect buttons.
Also you can add new buttons to a screen by going to screen tab and adding a button, (select your power button).
Colby wrote:#1 Go to the radio page... = Yes
#2 Open skin editor... =Yes
#3 select button tab... = maybe (not necessarily)
#4 select button to copy... =maybe. you dont select the button from the skin editor, you select it in the skin itself. once its selected or multiselected you can copy or cut
Cntrl+C... =Yes
#5 Now what ?
Then you paste this button(s) on the same screen if you want duplicates (they will be stacked in the exact location) or you can goto another page in the skin and paste (Cntrl+V) them there.
Colby wrote:Cntrl+Z = undo
Cntrl+S = Save
undo undoes everything after last save or exit of skin editor. So if I opened skin editor and moved something around, then resized something else undo would undo both, returning XL to the last saved state (that when you opened the skin editor). If you open skin editor and move a button then save (cntrl+S) then resize something else and hit undo, the resize would restore, but the move would be saved.
Also if you exit the skin editor at anytime it saves your skin state.
