New Xlobby Guide Available
Postby BaddaBing on Tue Feb 01, 2005 9:16 pm
While I created this guide specifically for my new KISS skin it contains plenty of information that can help the Newbie get up and running with Xlobby.
-system requirements
-required software
-preparing your media libraries
-configuring xlobby
-etc.
http://www.xlobby.com/files/badabing/files/Baddabings_Guide.pdf
-baddabing
BaddaBing
Postby ryang on Tue Feb 01, 2005 11:47 pm
great job, baddabing!
I think this will help newcomers learn the basic in and outs of xlobby.
ryang
ryang
Postby rika on Wed Feb 02, 2005 6:38 am
BaddaBing! Fargin butiful!!
Rika
rika
Postby rwh on Wed Feb 02, 2005 6:02 pm
Brilliant! Much needed to promote adoption of XLobby!
Can you post it under the Help pg of the website? Realize it's targetted at KISS, but there's still much generally useful material in it.
Thx muchly!
rwh
Help getting started.....
Postby FREDDYPD on Fri Jun 23, 2006 5:52 pm
Nice job. Thank you for the KISS skin. I am trying it out and like it very much. I can't seem to have my remote client play tracks from different CDs. I can make it work fine from the server. The client is able to play netradio over the server system. I also can't see any playlists. Maybe I did not set up winamp correctly?
Any suggestions?
FREDDYPD
Postby FREDDYPD on Fri Jun 23, 2006 6:24 pm
Just to clarify. At the server machine, I can select album, then select song and the menu will appear....(play track,play cd etc).......this menu does not pop up on the remote client side.
FREDDYPD
Postby FREDDYPD on Tue Jun 27, 2006 1:11 pm
Twit helped me with this one over in the general discussion board.
FREDDYPD
