- Physically plugged it in,
- WinXP detected it,
- installed the latest drivers from http://www.usbuirt.com
- downloaded USB-UIRT/XLobby plugin via the Download section of XLobby setup,
- went to IR Plugin, selected XLobby
- clicked "down", hit Set, pressed "down" on remote, clicked Learn until the plgin learned the signal
- did the same for "up", "left", "right", "enter"
When I go back into XLobby, anything I press on the remote acts like the "down" command. The USB-UIRT blinks, but won't do anything but go down on menus and such.
I'm not using Girder or anything else; just the XLobby plugin.
I am also using a BTC9019 RF keyboard; can't imagine that's causing problems, though.
Using latest XLobby2 release.
What am I doing wrong?
