getting black screen if i change skin
Postby tuvok2003 on Thu Dec 01, 2005 9:17 pm
Hi,
i'am just starting to use XLobby. After i get it installed i would like to change to a different skin. But with every "new" skin i get a black screen. After changing to the defaultskin back it works.
Any Ideas?
Thank you
tuvok2003
Postby Colby on Thu Dec 01, 2005 11:00 pm
Folders! There is a good chance you have skins nested in too deep. There should be a skins directory then the skinname folder. Inside that should be xmls, buttons folders, bgs etc.
Xlobby/Skins/NewSkin
Not: Xlobby/Skins/NewSkin/Newskin
When the screen is black can you hit f2 and open the setup menu?
It works
Postby tuvok2003 on Sat Dec 03, 2005 10:30 pm
Thx, for this hint. Now it works on this Box. On the second PC i have i have the same issue (black screen), but also w/ the default skin, and F2 isn't working.
Thank you,
Guido
tuvok2003
Postby Colby on Sun Dec 04, 2005 4:49 am
is .Net installed on the 2nd box?
