Postit widget
Postit widget
Postby tomprout on Mon Mar 19, 2007 8:55 am
Hi all !
From the screen capture of Colby from this thread :
http://www.xlobby.com/forum/viewtopic.p ... highlight=
I am looking for this kind of postit where I could write using my fingers on my touchscreen (not using keyboard !).
I found a lot of kind of this application but no one let me write using my fingers...
Any idea ?
Colby ?
tomprout
Postby jowaldo on Mon Mar 19, 2007 4:48 pm
nothin that i know of that will do that... plus writing on a touchscreen with your finger i'm assuming wouldn't look to great unless you are writing really huge. ;)
Postby tomprout on Mon Mar 19, 2007 5:17 pm
Pen would also be ok.
tomprout
Postby Colby on Mon Mar 19, 2007 9:49 pm
What inspired me for this post-it type thing was Crayola.com. My son "fingerpaints" on the touchscreen almost everyday. I am thinking I actually could make the post-it thing easily in flash, which I may do. My touchscreens always allow me to color with my finger. no different than a mouse, line size is set by brushsize not fingerwidth Jowaldo :)
Postby Marbles_00 on Mon Mar 19, 2007 10:18 pm
Sorry to hijack the thread for a moment.
Thanks for the crayola website Colby. I didn't think of that one. I've been trying to find some different sites for my daughter as she's exhausted a bunch of them already.
This should keep her occupied for a while.
Thanks again.
Postby dalanik on Mon Mar 19, 2007 10:28 pm
This shouldn't be too difficult to code, and I dunno what the difference between widget and a plugin would be.... :-)
Postby stevenhanna6 on Thu Mar 22, 2007 1:17 am
yah when I get more time I will explain the difference between what a widget can do. Basicly though, a widget will be both a stand alone application and a plugin...I mean I'm dumbing it down a lot to somethin realy basic so I don't have to spend hours explaining it...but widgets will have some pretty cool abilities a plugin can't do.
