ive been playing with the idea of using xlobby as a web portal
basically i want to set up a domain on a webserver and use xlobby on the home machine as a portal
i would strip out alot of the media stuff and simply make it a way to provide a portal to view/edit calendars or view/edit a database from a kiosk
anyone have any input on this
im not an xml genius but i would think you could specify a web link in the xml too whatever you want to access
it would require some sort of authentication to the server when you launch the portal maybe using sql
could this be done from a linux server or ould it have to be a windows server
i am interested to hear any thoughts on this
thanks
