Screen 0, screen 1 ,...
Postby ThE ScReW on Mon Mar 15, 2004 4:43 pm
I first tested xlobby with multiscreen.
If i use xlobby on my tv : screen 1 then i have a few problems : i don't see a photo slideshow; xlobby becomes grey but i don't see photo's anywhere.
If i change again and put xlobby on screen 0 : my computer then it works just fine.
second problem :
If i put xlobby in screen 1 : my tv and a click a movie then i can see xlobby in screen one and the movie plays on my computer screen, i want it just otherwise.
What to do?
ThE ScReW
Postby jowaldo on Mon Mar 15, 2004 6:54 pm
That sounds like a display driver configuration problem.
For example I have a dual head ati radeon card, and whichever display I want to play video (or anything that uses an overlay) I have to make it the primary display.
What video card or cards are you using?
Postby ThE ScReW on Mon Mar 15, 2004 7:03 pm
geforce 2MX/MX 400 i think
ThE ScReW
Postby jowaldo on Tue Mar 16, 2004 1:20 am
In the windows display properties window, go to settings, then you will see your two monitors listed there. Click on the montior that you want the video to be on, then click "use this device as the primary monitor"
That should do it.
