Xmedia2 by sagitaz www
Postby sagitaz on Mon Mar 21, 2005 12:15 am
http://www.france.xlobby.com/forum/sagi ... 2-ten2.gif
-Xmedia2 use all french plugin.
-Designed primarily for remote and keyboard, but you can use mouse and touchscreen.
-Native resolution is 1024x768
-French skin, the English language is ok now.
-update 21 juin 2006
http://www.france.xlobby.com/forum/sagitaz/Xmedia2TEN2.exe
sagitaz
Postby acemt01 on Mon Mar 21, 2005 5:16 am
Menu screen is VERY Nice. Hopefully more screenshots to come, and an english version too.
Mark
acemt01
Postby jmb295 on Mon Mar 21, 2005 2:55 pm
Looks great, and would love to give it a try!
jmb295
Postby dgemily on Mon Mar 21, 2005 5:08 pm
acemt01 wrote:Menu screen is VERY Nice. Hopefully more screenshots to come, and an english version too.
Mark
try with this translation file by C-moi :wink:
here:
http://france.xlobby.com/temp/XMedia.rar
Later,
dgemily
Postby Aaron on Mon Mar 21, 2005 5:28 pm
this is sweet and simple... i love it!
How do you use the translation file... sorry, never heard of it before.
Not that I would not like to learn French but my house guests probably would not want to just ot use the Xlobby :wink:
Aaron
Postby dgemily on Mon Mar 21, 2005 5:42 pm
Aaron wrote:this is sweet and simple... i love it!
just put the txt file in the repertory "languages" of xlobby, then launch xlobby, goto to the setup, tab "skin" select the file, that's it :wink:
here is the documentation by steven about the languages file : http://www.xlobby.com/Documentation/Languages
Later,
dgemily
Postby sagitaz on Thu May 19, 2005 8:44 pm
update :wink:
language txt files are in the skin file.
sagitaz
Postby sagitaz on Sun Jun 26, 2005 1:17 pm
update.
steven thx for ingeneer posibilities. but i change the title of topic with www at the end and i change resolutions of the pictures for 320*240 and it's not in tne skin topic. :?:
@+ and sorry for my english
sagitaz
Postby Chazotta on Mon Jun 27, 2005 11:39 pm
I have tried this skin at 1024x768 but for some reason some of the screen overlays etc are out place. What version of xlobby does this need ? Is there a specific plugin that you have to run in order for the skin to work properly ?
Chazotta
Postby sagitaz on Tue Jun 28, 2005 2:00 am
hy
i used xlobby2.exe version 1.0.1956.42388, XPluginSDK version 1.0.1937.25036 and the french plugin.
can you do a screen of the probleme please, when i test the upload version of my skin i don't have problem with overlay.
sorry for my english.
sagitaz
Postby Chazotta on Wed Jun 29, 2005 2:37 am
You're English is fine. You should see my French !!
I think it might be the French Plugin - I don't think I have this installed, can you please post the link - thanks.
Chazotta
Postby dgemily on Wed Jun 29, 2005 7:25 am
Chazotta wrote:I think it might be the French Plugin - I don't think I have this installed, can you please post the link - thanks.
look at there http://www.xlobby.com/forum/viewtopic.php?t=1979 or on the main page of the web site : http://www.xlobby.com/
Xmedia2 use :
- XAnt2
- XMoveWindow help : XMoveWindow plugin_us.doc
- Xradio
- XEvent
- XClock
- XMpc
- XRemote
But these plugins should not change something about the place of overlays…
Can you post a screenshot to see which overlays not correctly displayed….
Did you try at 800*600 ? it’s the original resolution, maybe some “aspect ratio” are not checked..
later
dgemily
Postby Chazotta on Thu Jun 30, 2005 12:19 am
Is there an English version of the French Pack 0.7.2 ? Even when I download the other plugins like XAnt2, the readme document is in French. Are there English versions ?
cheers
Edit: I have some screenshots, but I don't have anywhere to upload them. Can I email them ?
Chazotta
Postby dgemily on Thu Jun 30, 2005 4:18 pm
for Xant, there is not an english documentation.
we use it only to build some databases like movies.xml from Ant Movie Catalogue and we use it also for the cdaudio insertion, so if your are not using AMC you don't need really Xant.
maybe Xant will change a little bit, so it's better to wait before build an english documentation and the english users seem to be not interrested by this plugin, that why we didn't build an english documentation.
for the pack, there is not an english version too...
if you are interested by any plugin, let me know and I will try to explain you..
[quote=Chazotta]Edit: I have some screenshots, but I don't have anywhere to upload them. Can I email them ?[/quote]
yep, my email is dgemilyATgmail.com
later
dgemily
Postby dgemily on Sun Jul 03, 2005 4:38 pm
Chazotta,
I tried with 1024*768 and I have any problem... (Tested with the last release of xlobby2.exe)
but maybe the problem is because there is not "aspect ratio" checked for categories where you have some problems....
can you try with screens in this file: http://www.france.xlobby.com/forum/dgemily/temp/Xmedia2repkace.zip
just replace "screens/xml files" ( movies,music and apparence from xmedia2 directory's by the files in my zip file)
later,
dgemily
