Hello,
Two small but anoying questions regarding the albumscreen:
How does the musicdetails field on the music page knows what it has to display? Is it the name? (musicdetails show info on a selcted item in field music) or is it hard coded in xlobby?
If I set the music field to show text only (no icons) it will, when I select an item in the field, show the sub items. Can I change this so it will not go into the sub item, but only change the musicdetails field?
Arthur
