Objects with same URI Error?
Postby jmb295 on Thu Mar 09, 2006 1:14 am
I decided to do a clean install of xp again on my office pc, and am now attempting to get xnet running between two machines. My htpc has had xlobby for awhile on it.
I am seeing this error when trying to start the xnet server on the new installation. I've tried a new xlobby install as well and I get the same problem. Here is the debugging information if anyone has ideas?
Thanks...
System.Runtime.Remoting.RemotingException: Found two different objects associated with the same URI, '/1ce3fd1e_d4a1_496c_8437_d9fda5a4e301/office'.
at System.Runtime.Remoting.IdentityHolder.SetIdentity(Identity idObj, String URI, DuplicateIdentityOption duplicateOption)
at System.Runtime.Remoting.IdentityHolder.FindOrCreateServerIdentity(MarshalByRefObject obj, String objURI, Int32 flags)
at System.Runtime.Remoting.RemotingServices.GetOrCreateIdentity(MarshalByRefObject Obj, String ObjURI)
at System.Runtime.Remoting.RemotingServices.MarshalInternal(MarshalByRefObject Obj, String ObjURI, Type RequestedType, Boolean updateChannelData)
at System.Runtime.Remoting.RemotingServices.MarshalInternal(MarshalByRefObject Obj, String ObjURI, Type RequestedType)
at System.Runtime.Remoting.RemotingServices.Marshal(MarshalByRefObject Obj, String URI)
at xlobby2.Setup.StartServer(String server)
at xlobby2.Setup.button8_Click_1(Object sender, EventArgs e)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
Assembly Version: 1.0.1896.37708
Win32 Version: 1.0.1896.37708
CodeBase: file:///C:/xlobby2.2/xlobby2.exe
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
XPluginSDK
Assembly Version: 1.0.1893.28544
Win32 Version: 1.0.1893.28544
CodeBase: file:///C:/xlobby2.2/XPluginSDK.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
CDEX
Assembly Version: 1.0.1685.4787
Win32 Version: 1.0.1685.4787
CodeBase: file:///C:/xlobby2.2/plugins/CDEX.dll
xusbuirt
Assembly Version: 1.0.1767.29466
Win32 Version: 1.0.1767.29466
CodeBase: file:///C:/xlobby2.2/plugins/xusbuirt.dll
XWeather
Assembly Version: 1.0.1855.39961
Win32 Version: 1.0.1855.39961
CodeBase: file:///C:/xlobby2.2/plugins/xweather/XWeather.dll
Interop.Shell32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/xlobby2.2/Interop.Shell32.DLL
CustomMarshalers
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/xlobby2.2/AxInterop.SHDocVw.DLL
Interop.SHDocVw
CodeBase: file:///C:/xlobby2.2/Interop.SHDocVw.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Interop.ActiveHomeScriptLib
CodeBase: file:///C:/xlobby2.2/Interop.ActiveHomeScriptLib.DLL
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
enabled.
For example:
<configuration>
</configuration>
jmb295
Postby shmuck2002 on Sat Mar 11, 2006 8:26 pm
I Just had the same problem - setting up a second xLobby server as a "headless" media server, controlling it from my main. i got the same message when trying to XNet the two :( lil help for us?
shmuck2002
Postby vicom on Mon Mar 13, 2006 6:06 am
Sort of same kind of error with new installation on a thin PPC client. Used to work fine before upgrading to new XL and new PPC
vicom
Postby jmb295 on Fri Apr 21, 2006 2:31 pm
I'm still having this problem, any ideas out there?
I can't start the xnet server without an error saying there are 2 uris. I would like to connect to my ppc and one other xlobby server machine. I had this working several months ago, so I'm wondering if something has changed in the code to cause this?
I am able to start the webserver though.
jmb295
Postby jmb295 on Sat Apr 22, 2006 3:16 pm
I discovered that the error was being caused by winamp. When I removed that as my music player xlobby was able to start the xnet server. I unistalled winamp, and ran a registry cleaner to remove all of its entries. I then reinstalled winamp and it is running perfectly again.
jmb295
