No Movie Coverart and DB won't show all movie titles??
Postby usd1550 on Fri Oct 20, 2006 7:18 am
Ok I respect Steve for what he has developed but it has reached its point where I'm close to paying for a front end.
I've figured out a couple of issues that turned out to be of the bad install varity. This one is driving me up a wall. My music database imorted just fine but the movies end up not showing all the titles(just blank space) and no coverart? I've tried DVD profiler(which I like) but the only way to show all titles is to reinstall and ignore dvd profiler but again no matter what i try no coverart for movies (again music works just fine). I've double checked paths everything is pointing to the right place??
usd1550
Postby Marbles_00 on Fri Oct 20, 2006 3:32 pm
Have you considered Ant Movie Catalog (AMC) and the XAnt plugin? It works a charm. You just create a catalog that is contained and maintained in AMC. XAnt just extracts information/covers from the catalog/cover directory and creates its database.
Everytime Xlobby is started, Xant will update the database automatically. I'm sure that there is a way to refresh without leaving Xlobby, but you would have to talk to someone else about that one. But your primary concern right now is just getting a usable database up and running, which I know first hand, AMC and XANT can do.
The French Team did a wonderful job with this plugin and well worth a look.
Hope this helps.
Postby R32 on Sun Oct 22, 2006 5:12 pm
I believe you can do a refresh by creating an event in the event manager. XAnt has a rebuild function which I think will allow it to reimport your movie info.
R32
