by BaddaBing on Tue Feb 15, 2005 7:53 pm
Yes, it is possible, and your idea of how to do it is correct. And you may not even have to create any special screens, just set the "screen:" entry in the server.txt file on the client PC to "screen:menu". If the PC you want to run as a client has the same resolution as your server (or if the skin scales well) to it should work with no problems.
server:192.168.123.155 <- set to your XL server IP address.
screen:menu <- set to use the standard screens
resolution:auto
quality:100%
-baddabing
