skipping menu and going straight to DVD module?
Postby Grooby on Sun May 23, 2004 11:09 am
If i only wanted to use the DVD module and nothing else is there a way of going straight to this on load up skipping the menu screen?
Thanks :?:
Postby lar282 on Sun May 23, 2004 11:43 am
can't u just rename the menu.xml to menu_org.xml and rename the module you want to menu.xml?
Postby Colby on Sun May 23, 2004 2:26 pm
There is a checkbox in the upper right of the skin editor called defualt or something. This is checked on the screen that xlobby goes to upon load. Usually its the menu screen, you can uncheck menu and check the dvd screen and xlobby will load to here.
