how does theme's work
Postby rubbah on Sun Sep 12, 2004 4:48 pm
can't figure that out, i was hoping it would be something like a color theme so i could define a red theme a black theme and so on: like this..just by selecting theme
lars
rubbah
Re: how does theme's work
Postby dalanik on Mon Sep 13, 2004 8:48 am
I believe they just affect FONT and RECTANGLES colors...
Postby rubbah on Mon Sep 13, 2004 9:12 am
ok.. i just use a rectangle as background so that's what i want!
so if i clone my default skin and change the color assigned to the background the background should change when i select the new theme?
can't get it working that way..
rubbah
Postby stevenhanna6 on Tue Sep 14, 2004 6:33 am
no thats not how it works, you have to create a child. Just say you have a rectangle and its called "rectangle round" as the display resource name. You will add a child to that resource and give it the name of your theme...like "sony blue"...now whenever you are using "default" it will use "rectangle round" but when your using the "sony blue" theme it will use the child of "rectangle round" that is called "sony blue". Hope you follow that.
Postby rubbah on Tue Sep 14, 2004 6:49 am
aha.. think i bumped into something like that yesterday.. i though it was a bug.. but now i know.. Thanks steven..
rubbah
