Currently I have 2 instances of xlobby running, one in my bedroom and on in the living room. For the majority of the time I want them to both be running as a server, and then I can use my PDA to connect to whatever one I want.
Occassionally though I would like to sync the bedroom pc to the living room one. So to do this I need to stop the xnet server, control the other zone, and then do a sync all. I would like to set this up with one button press, but I'm not sure if you can do a start/stop of the xnet server from a button. Is something like this possible?
I know I can do it manually from the setup menu, but I'm trying to get everything configured so I never have to go into there. I'm working toward my own perfect setup. Thanks!
