by hjackson on Mon Nov 29, 2004 7:14 am
musicthebee, that is a very slow response. Is the laptop the server and the Simpad the client, or are you using both the laptop and Simpad as a client? I used to have a very slow response with the HeavyMetal server/client between my P4 HTPC and my touchscreen Progear client. The PPC client was nice and fast, as well, the default skin server/client speed was also fast. My HTPC had a 1280x720 resolution and my Progear has a 1024x768 res. Though I can't remember which was the biggest factor in improving the client/server speed, I had significant improvement after
1) I moved my wifi Access Point (802.11b)
2) changed the resolution of the client skin to 1024x768 (while keeping the server skin resloution at 1280x768)
The more I think about it though, the more it seems to me that the main hold up is Xlobby slowing down when converting the server resolution to the client's resolution. This would explain why the ppc with it's custom client resolution, and the default skin (which is natively in the same resolution as the CLIENT, not the server) works faster.
As an experiment, try the default skin. As well, change the server skin resolution to that of the client (I believe the Simpad is 800x600 and I assume your server is higher)
Good luck!
hjackson
