I have the folowing directories..
c:\program files\winamp garage\
c:\program files\winamp\
two wnamp installs not a copy over.
Then I...
1. shut down all instances of winamp
2. start the winamp.exe located in winamp garage
3. brought up the preferences dialog
4. click "output" under the "plug-ins" branch
5. select your output plugin and click "configure"
6. click the down box next to "device" and select which sound card will be used for this zone
7. CLOSE WINAMP
and repeat for each zone right...
When I change the output plugin it changes it for BOTH copies!??
I made sure only one was running.
Any suggestions?
Rob
